Silverstone SX600-G PCI-e Cable Question
Moogoos
I am thinking of getting a GTX 980 SC and using this PSU. The GTX 980 SC I believe has 2 6 pin power plugs but the PSU only has 1 blue 8 pin PCIe out. How would I wire this card?
Thanks!
Edit: NM seems it has dual 6/8 pin PCIe
Thanks!
I think you can go cheaper and do the new 500W SFX L from them. It should have the two 6/2 pin too as well. At least thats what i digged up. If someone can confirm that would be helpful.
