Silverstone SUGO SG09 SFF Case
HardOCP News
[H] News
The fellas at eTeknix have a review posted today of the Silverstone SUGO SG09 small forma factor case. Check it out if you have plans to build a LAN box or HTPC.
As you can see from the specifications below, the SG09 may be small but it's capable of housing either Micro-ATX, DTX or Mini-ITX motherboards, giving it a wide range of compatible motherboards to choose from. Add to this the fact that it comes equipped with three fans as standard, support for two 3.5" hard drives, four 2.5" hard drives, a slim optical drive, large CPU coolers and long graphics cards! All of which is impressive for a chassis of this size.
I think my only real gripe with the design is that they moved away from the ITX-only form factor. The previous Sugo cases were brilliant for SFF and HTPC use, and this new case is now just a wee bit too tall to fit on the lower shelf of my home theater unit.
Should make for a great LAN box, though.
love this case and the cable routing that can be achieved. Im narrowed down to this or a Fractal case.
