Silverstone Sugo SG02
KeymaN
is it possible to take apart the whole case?
i m planning to paint the whole thing ;)
Well the top/side cover and front panel comes off, enough to paint the interior, but if you want to take it completly apart you can drill the rivets out then mount everything back on if you have a rivet gun. But that's something you can do with any case...
alright then i will give it a look tmr
but i was wondering that is it ez to remove the front panel and does the front I/O stuff attach to the front panel of the chassis itself
