Silverstone Strider or Zeus?
mytmouse
So right now I am trying to decide between the ST60F and the ST65ZF, I can't really consider many other PSUs as they just aren't availiable. I can get either of these tomorrow, just need to know which is the better of the two.
My understanding:
The ST60F is modular 600W with 120MM fan and is produced by Enchance.
The ST65ZF is non-modular 650W with 80MM fan and is produced by Estatis.
If it were me, I'd probably go with the Zeus. However, I do most of my PSU buying these days based on reviews and rankings generated by JonnyGURU and Co. Now, not everyone agrees with them but I do and so this is my advice to you.
- JT
I will be running for the time being.
Opteron 170 (overclocked)
A8N-SLI Deluxe
6600GT PCI-E (planning on 8800 upgrade soon)
2x74GB WD Raptors
6x500GB WD
A few 120mm fans
600W should be heaps?
zeus is bit higher quality if you dont need the modular desin go with zeus. I have 750w strider and 850 zeus they are both great power supply.
