Ingonuts13
- Jun 9, 2003
Ok so here is the problem I am experiencing and the steps I have taken so far:
My system will randomly completely shut off during intense 3d Apps like games or the Luna demo.
I am running these specs and everything is brand new with a fresh install of windows. Nothing is overclocked at all.
DFI LANPARTY UT nF4 SLI-DR Expert
AMD Opteron 175 Denmark
2x 1GB Mushkin Redline PC4000
2x BFG 7800GTX 512MB
DVD-RW
WD 74GB Raptors
Creative SOUND BLASTER X-Fi Fatal1ty
Silverstone ST60F
So far I have run Prime95 overnight for 12+ hours no problem. I am also currently running just one of the GTX's to see if possibly one is defective. I don't think this to be the case though, since usually if a vid card is defective, it is defective.
I have checked the system for heat issues and there seem to be none. Both GPUs never break 60C and the the CPU is never above 50C.
What has me stumped is that it seems to only happen when running SLI and very intense 3D Apps.
Now I have an SLI certified PSU with plenty of juice.
Does this sound like the PSU is bumm? I have read somewhere about crossloading issues with the Silverstone, but I do not think I am drawing over 30A on the 12V rails.
I have also tested both cards individually without issue in either slot.
This HAS to be a PSU problem. Am I drawing more than the rated amps?
24Pin ATX connecor is using 12V3
4Pin Molexes use 12V4
SATAS use 12V2
EPS12V 8PIN uses 12V1 and 12V2
6PIN PCIExpress Connectors use 12V3
For Max Load:
12v1 13a
12v2 18a
12v3 16a
12v4 8a
DVD-RW
WD 74GB Raptors
Silverstone ST60F
SATAS use 12V2
For Max Load:
12v1 13a
12v2 18a
12v3 16a
12v4 8a
