Silverstone SST-TJ04 Your thoughts?
acee
well i'm planning to upgrade my antec 900 to another case soon and I've been looking at the SST-TJ04 as its pretty fairly priced and its made out of aluminum which is what i've been looking for :)
so, I just wanna know if this case is a good case to upgrade to?
Thanks
Actually, that case has a steel body, and an aluminum bezel. It's a good case though!
steel body.. so that means its the same as any other case out there? I'm guessing thats the reason why its so cheap :(
No, because unlike every other case out there Silverstones are sturdy, and look stunning. Trust me, if you pick it up you will not be disappointed. Have you considered a bigger case? Like a TJ06 or an 05? Those case are awesome!
I have looked at the TJ 09 but for 285 over here. I don't have that kind of $$ for a new case :(
The TJ06 is a great choice, so is the TJ05. Hell the TJ04 is awesome case as well, you shouldn't be put off by case just because the case isn't entirely constructed of aluminum. There are many cases out there which are all aluminum, but still suck (skyhawk cases come to mind). Personally I've never worked with any better cases then what I've seen from Silverstone. I own the TJ06, TJ08, and the TJ09, and all are of the highest quality. The only other cases that match up to Silverstone, are Lian-Li, and old Cooler Master ATCS cases (which I also own a number of) Basically, you will not be disappointed by a "hybrid" case such as the TJ04.
I too am looking at the TJ04 and the only concern I have is for cooling. Does it only have a 120 in front and back for cooling options.
I'm worried that if I run SLI 8800GT's there won't be enough airflow to cool them down.
Any thoughts?
It looks like Digital Storm can modify this case if you buy from them. You can add an extra 120 in the front for extra circulation. Not a bad idea.
