Silverstone SST-PS07B
Greatone123
My search on the forum has turned up nothing, about this case. Does anyone have this case? or at least seen images to help answer my questions maybe...
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163186
I was wanting to do some water cooling but keep the form factor small (mATX) I came across this case and the case is everything I wanted in a case. I noticed the 2 120mm fans up front. Now my question is this, is there enough clearance at the bottom of the fans for a 240mm radiator (where the hose barbs usually would stick out)?
I haven't chosen a radiator yet because of the area in question. was thinking about the XSPC EX240 : Dimensions: 121 x 35.5 x 275mm (WxDxH)
I haven't really looked at them, but if a regular rad won't fit would a corsair 240 kit fit ? I don't know if they have any different in size or not then a DIY rad.
yeah after I read through the tj08e thread... I came across that... newegg has it as PS07B so when I searched for that nothing came up...
