skinnychicken
- Jun 7, 2004
Does anyone know if the handle on the SG04-FH is easily removable, or is it more or less a permanent part of the case?
Thanks
Edit: After some more research, it seems the rear of the handle is held on by screws, but I'm not sure about the front. Either way, I like the case, it would just be nice to have the option to change it out when you wanted.
Thanks
