Silverstone SG02 SB i7 build Cooling solution needed
Hey Guys, Im building an Silverstone SG02F
with these components
GIGABYTE GA-Z68MX-UD2H-B3
Core i7 2600k
2x 4GB Gskill 1600mhz
OCZ ModXStream 600W
Ati 6850 - undecided on any specific model
CrucialM4 128GB SSD
1TB samsung F3
OEM DVD drive
Fan controller on 3.5 inch bay
Wondering what would be the best available cooling solution available today.
Unsure on whether the CPU cooler should be a push or pull set up.
Also unsure whether if i would damage the psu if i decide to go with a NT06 Evolution and blow air out through the PSU.
Planning on using the Kozuti and switching the fan orientation to pull air from the CPU and add an additional fan on top of the kozuti to boost airflow.
In addition i plan to add 2 40MM fans in the vents between the mobo and psu and maybe a fan on the side ( north of the MOBO )
The last option would be to use a PSU that has a rear fan instead of a 120mm fan inside the case. ( Antec Earthwatts 500D) and use a cooler such as the HPL 815 from evergreen.
Thanks.
Recommendations is what I need!
