SilverStone SFX ST45SF 450W PSU
HardOCP News
[H] News
PC Perspective has just posted a review of the SilverStone SFX ST45SF 450W PSU. If you need a decent 450W power supply for your SFX project, the crew at PCPer says this just might be what you are looking for.
The SilverStone ST45SF is a good SFX form factor power supply. It has many of the features that you would expect from larger ATX enthusiast PSUs like a painted chassis and sleeved cables. The power supply delivered good voltage regulation with good efficiency and maintained relatively clean outputs across a wide range of loads. The ST45SF also comes with both EPS12V and PCI-E connectors, which typically aren't found on a small SFX form factor PSU.
