Fan noise seems to be less of an issue with the non-modular 450W.
Ah OK, I changed my comment. I remembered people saying it wasn't as loud but I'm not sure.Actually, the non-modular bronze 450W also rather loud under load.
I have a V2.0 and it was quiet at first, then after a few months, it got a lot louder out of nowhere. I suspect a failing fan bearing. I'm also not the only one where V2.0 has not solved the noise issue, since the real problem seems to be the fan, not the fan profile that got changed with V2.0.There's also the 450W V2 which addressed the fan volume level.
Some people have been complaining about the noise at load with the modular 450W and have replaced it's fan (requires soldering or adapter) but it also makes the PSU overheat when it's supplied hot air.
Fan noise seems to be also an issue with the non-modular 450W.
Most are looking forward to the 600W which has a different fan and a different fan profile, which should mean it is going to be a lot quieter. And some are looking forward to the 500W SFX-L with a 120mm fan, but it doesn't fit all cases because it's a little longer (hence the 'L').
You just have to be mindful.
As an example, a user in this subforum named OverRated has done the fan-mod on the ST45SF-G, has a i7-4770K and GTX 780Ti, has a Demciflex filter on the fan of the PSU and he uses an Ncase M1 which has a small retention in warm air exiting out of the PSU. All this is not a problem on it's own or bad design, but OverRated has had stability issues because ALL these aspects are combined.
If possible, wait for the 600W SFX PSU or the 500W SFX-L PSU (if it fits). These have lower noise as a important design point and you don't have to void your warranty and buy a fan + adapter to "fix" it. But it will also avoid another problematic aspect.
here is the thing, im planning on ordering parts tomorrow. What do you suggest? http://pcpartpicker.com/user/Schwizzle/saved/y3LcCJ
I recommend getting the Crucial VLP Sport, someone had issues with the Tactical on the ASRock motherboard getting it to work properly.
If you need/want to start building within the week, you can't wait on the 600W (due in a few weeks) or 500W (unknown at this time). Getting the Bronze is not a bad choice if you are planning on upgrading and it should be enough for your hardware (single GPU, no OC'ing ?).
..I updated the ram, where these the ones you meant?
Yep those are the ones. Mind you, you selected a single stick of 8GB. Unless you are planning to expand to 16GB, it is best to get 2x 4GB for Dual Channel.
The SilverStone NT06-PRO cooler will allow better overclocking than the Noctua NH-L9i.
I know, but I hear talk of psu overheating, how does that stack up?
I always think that heat output from the CPU is the last thing to worry about, unless you're running AMD FX-9590. It's always the GPU's fault.
That's not what I mean. The hot air is expelled into the psu, won't that overheat it?
