Silverstone SFF T004
WorldExclusive
Not sure of the name, you can barely see it in to bottom of the second photo.
This is not a case. It's designed to connect a laptop to via thunderbolt to use a full graphics card. So kind of like a docking station.
I'm more interested by the case on the right of the LCD....Seems like a smaller SG05.
My god that enclosure is big for only housing a graphics card. It's more volume than an SG05.
Now granted you can get a mini itx motherboard with no expansion slots populated into a pretty small box. Or better yet, how about an Intel NUC with this thing attached to it. He'll you could probably put a NUC inside this and still have room for water cooling the GPU.
It looks like you could fit a fat 140mm radiator with dual push/pull fans on the bottom.
I hope the 004 part means they have other, smaller versions of this. Make one that is 300mm deep, by 125mm wide, by 125mm high would be about perfect.
Thunderbolt may finally get a reason to exist if this thing becomes a reality.
Is this thing leaving enough space for water cooling kit or something on the other side?
Now we just need more thunderbolt enabled tablets. :/
And I mean non-Acer ones, I have un-erase-able scars from Acers :/
