Hello SFF people! I recently built a system in a Corsair 250D and after seeing it, a friend wants me to build one for them but in a Silverstone RVZ01. So I just want to make sure of a few things.
PSU Questions:
1) Looking at the Silverstone site it seems to indicate that a SFF-L PSU will fit? Is this a standard size where any will fit?
2) And I did look into the SFF-L comparison thread but it seems to be more a listing than a comparison. Are any of the 500w models better than others?
3) Lastly I'm pretty sure that 500w will be fine for a midrange to upper midrange gaming system?
CPU HSF Questions:
1) The CPU will be a A10-7870K, would a SS Argon AR06 be better than the rather impressive stock cooler? With beefier heatpipes and a larger fan I imagine yes, but doesn't hurt to ask.
2) Is the Argon the same size as the stock cooler? Trying to do some measurements of the stock cooler in the case it appears to be 92mm by 101mm which is just about the same size. I ask as the RAM is about 1 or 2mm from touching the stock so one side can't get any bigger.
Case Fans:
1) From what I've read the case requires the slim 15mm fans?
2) Any suggestions as to what fans to get? Not exactly a huge selection on NewEgg.
Thanks for taking the time to read this!
PSU Questions:
CPU HSF Questions:
Case Fans:
