- May 2, 2006
What has your experience been so far? would you recommend it over the HAF X? any issues/problems?
I love my raven case. I will purchase another one when I rebuild. I bought one for my son's rig as well and got one of their sff cases for the wifes build. The cooling is by far the best I have owned. The case is so quiet. The only down side is the size, they are pretty big. The pics don't do them justice on size....
I've got a RV02-EW - not sure what board and CPU you're running BroHamBone,
So instead of using the platform feet they provide in the case hardware... I just put my kuhler 920 on top of the 180mm fan w/ both 120 fans in push/pull ... wow how cool it stays. Has not gone above 34.1C. Tooo funny!
So you have the 180mm fan, followed by a 120mm fan, then radiator, and another 120mm fan??? Why not just mount the stack to the exhaust fan hole then?
