Hi,
As you can probably guess from the title, I've been checking out the RV02 Evo.
I am planning a new build, using a Corsair AX1200 PSU, and was wondering if I'd need extensions to reach the HDD bays, or any other part of the Raven.
Also, I plan to go 3way sli / crossfire at some point, and it doesnt look like there's room for a dual slot card in the last expansion slot, seems like the optical drive connectors might be an issue.
Also, what's the maximum CPU heatsink height I'll be able to get away with?
Any help is greatly appreciated.
Djac.
Djac.
