Silverstone Olympia OP1000?
clubsport
Hi all,
Does anyone know, if there are reviews on this power supply Silverstone Olympia OP1000?
I have been debating on this and Pcpower 1kw , pcpwer 750 silencer
clubsport said:
Hi all,
I haven't seen the Olympia available in the US yet. It is the same unit as the Seventeam ST1000E without the OCP and the 12v's bridged. You can see that unit here: http://www.jonnyguru.com/forums/showthread.php?t=174
clubsport said:
Is it important to have 1 rail of 12volt than 3 or 4?
It doesn't matter so long as you make sure you aren't going to overdraw a rail......single rail PSU's avoid this concern. But functionally no it isn't important if you are observant.
I just found out that the New Silverstone 1000 psu will come out at the end of December for the price of US330 ;)
It's the same product.
Silverstone just had SevenTeam solder jumpers across the four +12V rails and remove the OCP.
Keian ordered theirs with just the two PCI-e rails soldered together and the OCP increased.
End result is still the same.
still a hell of a lot cheaper than the PCP&C 1kW-SR
Yes!
And in my humble opinion.... just as good of a choice.
SevenTeam kicks the proverbial ass.
