Silverstone ML05/6 - vertical orientation?
max789
Hi, all
Has anyone considered whether the Silverstone ML05/6 can be used in a vertical orientation? This would make a superb alternative to the dated Antec ISK-300/310.
Should Tony Ou chance to read this thread, any input from him would be greatly appreciated.
Thanks in advance!
Since rubber feet included with the case aren't applied from the factory, you can technically stick them on the PSU side of the case and use it vertically without any problems.
However, I don't think it'll look as good since we didn't design the front panel for vertical use.
Many thanks for your helpful reply, Tony.
I'll now wait for the ML06...
