mattchapman
- Dec 30, 2005
Has anyone used the Silverstone ML03 case?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163174
I want something a little smaller than your usual 6" high behemoths.
I considered the Antec Micro Fusion 350 but read terrible things about the LCD.
Then I found the Lian Li PC-C37 which seems great except its expensive ($150).
I'm thinking the ML03 at $70 could be a cheaper alternative.
I would be installing an AMD CPU, mobo, optical drive, 1HD and 1SSD and probably a passive 5450 and TV tuner down the road.
Thanks
Thanks
