Thought I'd share my new HTPC build after my older board died, decided to replace the case as well. With some modification, I kept the same power supply (case designed for a SFX, but I reused a TFX instead) and installed a "fanless" heatsink for the APU. I'll keep an eye on temps and see if I can get away with just having the power supply fan cool the whole system, not sure yet. The bluray drive over the cpu limits heat exhausting upwards out of the case.
The apu heatsink was an Arctic Cooling Alpine 64 Plus. I used a hacksaw to cut 5 fins off each side and spread them slightly, then drilled/tapped the bottom of the heatsink to line up with the mounting holes in the ASRock QC5000-ITX motherboard.
With Bluray drive installed:
The TFX power supply was a press-fit. I had to cut the back rail a little and bend the SFX support to get it to fit but it worked.
Fun weekend project putting this together!
