Salaminizer
- Sep 21, 2006
I just ordered a Silverstone LC20 to make a HTPC and was trying to figure out which way the fan on the side of the case should be pointing. I first thought a side fan would be an intake, but it is kind of near the back of the case and also near the main 2 back fans, and I am not sure if it is also supposed to be an exhaust.
Front fans blow in, rear fans blow out. What about the side near the rear? The side grate will be near where the motherboard and cpu will end up if that helps.
Here is a pic of the case -
http://www.silverstonetek.com/products/lc20/interior/LC20.jpg
This is a top down view with the front of the case on top and the fan in question will be on the left hand side near the bottom.
