I'm looking at buying a new power supply for a tiny ITX case called the Osmi.
http://hg-computers.eu/product/osmi-case-only/
https://www.pinterest.com/pin/564287028288233930/
The choices of power supply on my radar are:
SILVERSTONE ST45SF-G
or
SILVERSTONE SFX Series SX600-G 600W
I'm leaning towards the 600W because it comes already with a flat cable albeit long kit (routing will be difficult) where I'll likely have to buy a short cable kit for the ST45SF-G.
Things I'm curious about. How loud is the 600W over the 450W? Considering the system will be peaking closer to 300W from the mains is 450W enough or am I better off with the 600 to be around the magical 50% load curve, or does it even matter as these are gold rated power supplies? Will idle power consumption be much better with the 450W?
Do the fans on the 450 ramp up and get louder when under loads that hit over 50%?
Here are the rest of the components.
Core i7-4790K with low profile cooler (cooler TBD)
GIGABYTE GA-Z97N-WIFI motherboard or ASRock Z97E-ITX/ac
2*8GB 1.35 volt low profile DDR3 1600 (Crucial Ballistix Sport)
Sapphire Radeon Fury Nano GPU
480GB Intel 730 SSD
1TB 7200 RPM Seagate HDD, single platter.
Slim Bluray Drive (TBD)
140mm BeQuiet! system fan.
Any advice here would be appreciated.
or
480GB Intel 730 SSD
