no usb 3.0?
Aftermarket CPU HSF height is the only limiting factor.
This is the cooler that sits atop my 2500k in this case. The newer version is only 100mm while this one has a low pro 120mm fan and performs better. They can still be found if you hunt around.This is what worked best for me:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185129
I think this is the newer version:
Are the front USB ports 2.0 or 3.0?Sweet, ordered one. Thanks.
One of these really makes installation much less of a pain if, like me, you hate push pins.
Any idea where to get the 3.0 version? Or is the upgrade kit the only way to make this happen?this model they're 2.0, the GD06b had the 3.0 and looks a little nicer for an extra ~$50. BTW it's up to $80 presently.
The GD06b is the version of this case with USB 3.0 front hookups. Amazon has them for $122 right now.Any idea where to get the 3.0 version? Or is the upgrade kit the only way to make this happen?
According to Silverstone's website and comments on Newegg, there is a USB 3.0 version of the GD05. Model number is SST-GD05B-USB3.0 (http://www.silverstonetek.com/product.php?pid=241&area=en). The only place I can find it is in the Pacific countries (Japan, Australia, etc.). As I was typing this, I found an adapter kit for a lot of the Silverstone cases: http://www.ebay.com/itm/Silverstone-2xUSB3-0-2xAudio-USB3-0-Upgrade-Kit-G11303260-/280853223388.The GD06b is the version of this case with USB 3.0 front hookups. Amazon has them for $122 right now.
While USB 3.0 front ports are nice, the GD06b is more cramped inside, especially the PSU area.
If you don't plan on installing a DVD or BR drive in your case, you could install a card reader with USB 3.0 ports that fits into the open 5.25" bay, on the GD05b to get your USB 3.0 front connects.
Whoa I hadn't seen this! Looks like the GD05 is listed as being compatible with that adapter. Nice find!As I was typing this, I found an adapter kit for a lot of the Silverstone cases: http://www.ebay.com/itm/Silverstone-2xUSB3-0-2xAudio-USB3-0-Upgrade-Kit-G11303260-/280853223388.
