bobsabigboy
- Aug 30, 2016
I have the FTZ01 case standing vertically and had a couple of questions regarding cooling. I'm using a Noctua NH-L9x65 as my cpu cooler and have 2 stock 120mm case fans next to each other. Under load, my temps will reach 75*c-80*c pretty easily so I'm thinking about changing the fans but not sure how much of a difference it will make. Here's what I'm thinking:
Change the (2) 120x15mm (32 cfm, 2000 rpms) with (2) 120x25mm (64 cfm, 1500 rpms). Should both of these fans be facing out?
As for the cpu cooler, it currently has a 92x14mm fan (30 cfm, 2200 rpms) and change it out for a 92x25mm fan (46 cfm, 2000 rpms). It is blowing out of a 120mm case fan slot. Or I can keep the 92x14mm fan and add a 120mmx15mm (58 cfm, 1600 rpms) in the empty fan slot. If I did this, the cpu fan and case fan will only be 3mm apart from each other. Should this case fan be facing out as well?
Let me know your thoughts. Thanks.
