jdogg707
- Jan 5, 2004
I am looking to attempt water cooling for the first time and it has become apparent that I couldn't have chosen a worst case for it! Unfortunately I love everything else about my case, so I don't want to give it up and am willing to work around it to make water cooling work. My goals for the project are to make my system as silent as possible, as well as to maintain cool temperatures during operation/gaming/video encoding.
My current system consists of:
Intel Core i7-2600K CPU @ 4.5GHz
Asus Sabertooth P67 Rev. 3 Motherboard
16GB G.Skill Ripjaws Z RAM
2xSapphire Radeon 7970 Video Cards
256GB Vertex 3 Max IOPS SSD
512GB Crucial M4 SSD
2x2TB Western Digital RE4 Hard Drives
Corsair AX1200 1200W PSU
Noctua DH-14 HSF
Silverstone FT02 Full Tower Case
My temperatures currently are very good (67C at load on Intel Burn Test) and video cards both stay under 80C during Furmark. However, the current environment is quite loud, since all of my fans have to be running at higher speeds in order to maintain the cooler temperatures (especially after adding the two 7970's). I am hoping to bring the noise level down quite a bit, while maintaining or improving upon my current temperatures.
After some research, here is my current shopping list:
XSPC RX120 Radiator
Magicool Extreme Dual 180mm Radiator
XSPC Dual 5.25" Bay Resevoir
Swiftech MCP655 w/Speed Control
EK Supreme HF CPU Block - Nickel Plated
EK Radeon 7970 VGA Block - Nickel Plated
EK Radeon 7970 Single Slot I/O Bracket
EK Radeon FC Link for Crossfire
PrimoChill PrimoFlex Pro LRT Tubing 1/2" to 3/4"
IandH Silver Kill Coil
Bitspower Black Ultimate 1/2" to 3/4" Rotary Compression Fitting
Bitspower Black Ultimate 1/2" to 3/4" 45 Degree Rotary Compression Fitting (For CPU Block)
Scythe Gentle Typhoon 120mm 1850RPM Fan
At this point, I plan on using the 360mm radiator with two of the existing 180mm fans in my case, then attaching the 120mm radiator to the top fan cutout on my case and attach two of the gentle typhoons in a push pull scenario. I figured my loop would look something like this:
360mm Radiator --> CPU Block --> 120mm Radiator --> Video Cards --> Reservoir/Pump --> 360mm Radiator
Finally, other than looking for general guidance on whether you think the above plan will meet my goals for the project, I have the following questions:
1. It is my understanding that the combination of the kill coil, with distilled water, will make for the most efficient cooling liquid. Is there something else I should be looking at?
2. Should I be looking at the addition of a drain line to help ease the process of draining my loop? If so, where would you recommend I put it?
3. Are the Koolance quick connect adapters helpful? Should I be looking at placing them somewhere in the loop?
4. Should I be looking at something that helps measure flow? If so, recommendations?
As this is my first water cooling project, any help is greatly appreciated!
Noctua DH-14 HSF
XSPC RX120 Radiator
