I want to be the first to mod this one, and do it justice.
I took a decent wallpaper and rendered out the background:
BEFORE:
AFTER:
Then made the render into a digital applique:
AFTER PRINT:
The Plan is to take an acrylic case, and mod the entire case to look like space, and the open side will have silver surfer , moon, and planet. To get the space effect I'm either going to cover the inside of the case with a vinyl wrap with stars and planets cut out,
or make mini appliques (templates) of planets and stars, stick them to the inside of case and paint it with plasti-coat, than remove the appliques to lets light shine throught those areas. Im not sure if I should use UV lights, or Ultra Whites ??? I guess i'll have to
test both... The first thing I have to do is cut out the appliques, then decide on a clear case........
BEFORE:
AFTER:
AFTER PRINT:
