Silly question about SFF and beefy power supplies
fishermd
Greetings, everyone.
This is my first post here, I'm a newly joined member, and am building my first SFF this month. (I'll add the specs to a future post, as the tradition seems to be...) <grin>
I will likely be going with the silverstone SG01B, and an asus A8N-VM CSM motherboard. I am going to try to stick with a single vendor for some of the more closely related components (case, power supply and heatsink (the NT03 fan/heatsink looks pretty sweet, btw)).
Which brings me to my question: the only modular power supply that Silverstone carries is the ST60F which is 600W; and staggeringly more powerful than this system will need. Are there any disadvantages to having such an overpowered PS (other than cost)?
I would think that because it isn't taxed in the least, it would run particularly cool and quiet--but this is a bit outside of my experience.
Comments?
I think the Antec neopower 480W (not HE) or OCZ modstream 520W would be a better bet. Better bang for buck than that Silverstone PSU.
No need to stick with the same manufactuerer for everything. Using different makes of parts is part of custom building. I have an Antec Neo480 in my Silverstone SG01. Having more than enough power is better than not enough.
As for HSF here is one POST that did NOT get good temps with the Silverstone cooler. (Start reading around Sept 20th in the thread). (I am using a Zalman 7700B-Cu on my Biostar.)
I'm pretty sure most 600w PSUs are bigger though...aren't they? I would assume they run hotter as well.
nope and nope
the only way it reason it would run hotter is if there's high current draw from power hungry components, otherwise it isn't consuming more wattage than say... a 400watt psu.
