Silicon Graphics Cases
Format _C:
Has any one moded one of these
and if so will it fit a full ATX mainboard? I like the look of those cases and I want to mod one I'm just wondering if any body else did one
Oh yes, many moons ago. To answer your question, no, most ATX motherboards will not fit as the case isn't that deep (IIRC about 1-1/2 or 2" too shallow or around 8" deep). That said there are some very specific motherboards that will work, you just need to ask yourself if it is worth it.
Another thing, there is a metal inner case under all that plastic, in fact just two tabs on the bottom hold the plastic outer case onto the inner one. Depending on what you want to do with it fitting something in there isn't hard...
Hope that helps.
Not sure, I can dig around in the basement tonight and see if I still have that case, if not I know I have another Indigo that I can take apart and show you what I meant. Would that help?
