Silently removing Mcafee Security Scan Plus
cyclone3d
After searching the web for instructions on how to remove Mcafee Security Scan Plus, the only valid instrctioons I found were for version 2.0.x
After installing the newer version 3.0.x and doing some digging around I found an .ini file that gave me the command to do the uninstall of 3.0.x silently.
2.0.x silent command is:
on 32-bit:
"%ProgramFiles%\McAfee Security Scan\uninstall.exe" /S
on 64-bit:
"%ProgramFiles(x86)%\McAfee Security Scan\uninstall.exe" /S
3.0.x silent command is:
on 32-bit:
"%ProgramFiles%\McAfee Security Scan\uninstall.exe" /S /inner
on 64-bit:
"%ProgramFiles(x86)%\McAfee Security Scan\uninstall.exe" /S /inner
I am guessing that the 3.0.x command might also work on 2.0.x, but since I have no computers with 2.0.x installed, I have no way of testing.
The other way to uninstall 3.0.x silently is to edit the .ini file and delete the options under the [UIFLOW] section and then just run uninstall.exe.
