Silently cooling 9600XT
Grizzy
I have a VisionTek 9600XT video card, and the HSF on it is fairly small and very loud
I want to replace it with something larger and have either no fan or a very very quiet fan on it. I was thinking of just modding a old socket 7 type HSF with mounting holes and putting that on there with a silent fan, but don't know if the weight will be an issue, or the amount of power draw from the fan (hoping to just solder connectors so I can use the video card's fan power header)
I am hoping to do this for about $10, so if anybody knows the best way to cool this video card silently, that would be great
http://directron.com/dc1206bmr.html
http://directron.com/fce6010.html
http://directron.com/dp55g11a.html
http://directron.com/fan-p-b.html
http://directron.com/fan-p-ss7.html
http://coolerguys.com/ProductDetail...?productID=1155
I would be volt modding the fans somehow to run them silently
I already have the last one, but I think it is too big/heavy to mount on a video card... what do you think?
Post links to products, reviews, anything
Thanks
Dan
I found a stock AMD HSF in my room, has a few scratches on the base
If I can't find anything else, I guess I can always lap the base of that, slap a quiet 60mm fan on it and use that...
Any other suggestions? Not going to overclock it at all, just want silence
