In order to start a car the battery must supply 100 to 200 amps of current over a short period of time.
It's a +12V source. The power is coming from the PSU, not the wall (and I don't think a car would operate off of AC anyway).29 amps with 120v source
Actually, the PSU is running off a 240V source.the psu is plugged into a 120v source was my point although you are correct it is a 12v step down at the power supply...
Regardless of how much you try and lessen the load, there is still no way that a PSU capable of outputting 34A could possibly start a car on its own. That kind of load would either kill the PSU outright or trip its OCP instantly.notice the car also didnt seem to run very well at first, could be that the accessory belts were all removed to lessen the load on the starter
a vehicle alternator is nothing more than an AC generator with diodes to make it DC and a voltage regulator to step voltage down to 14 give or take
i say its plausible based off of the crappy batteries i test daily at work that still manage to start a car and the tiny jump start boxes that will give a car enough amperage to start off of a 12 volt battery
It's meant to be a viral video. It doesn't have to be true, it just has to catch peoples' attention (which it seems to have accomplished).well i am sure an EE in the house will soon chime in, i am pretty sure Cooler Master would not jeopardize their reputation by creating false claims, it would be financial suicide
i believe it to be probable
