Silent PCI-E XL card advice
Wally
OK, for no real reason other than the XL chipset runs really cool, and can therefore be trusted with a passive/silent cooling solution, which would you recommend i go for:
Sapphire X800XL Ultimate
Liking: Zalman coooling, quiet and good cooling, plus spiffy colour theme
Not liking: Sapphire's crappy bundles, though that's not really a deciding factor, tbh
OR
Gigabyte GV-RX80L256blahblah
Liking: total silence, Gigabyte's bundle and presentation
Not liking: reliance on good airflow, limit to overclocking due to obvious heat problems
So, apart from that, has anyone got any advice to offer, i.e. build quality, which is better in terms of clockspeeds, any likely problems, etc etc? Basically, i'd be happy to hear anyone's reasons for one card or the other, just so i get a wide spectrum of opinion and anything i may have overlooked.
Oh, and which tends to be cheaper :D
I take it the Sapphire's taking up an adjacent slot isn't an issue? Also, the poor bundles shouldn't be an issue any more. Check out Tom's (I think) recent article about how they're giving the consumer a choice on which games to include.
I wouldn't worry about Gigabyte's solution, since they put this same cooler on their 6800GT. However, I would expect Sapphire's card to be cheaper.
lol, i tried reading that but got bored, i'll take another ppek now, thanks
:D
as for the gigglybyte, it's quite possible i can get one for about £150-170, when it retails (or most XLs do anyway) at about £230. Another option is getting a ViVo version of a card, which i hear comes with a power connecter rather than running off the board, which'll give more room for overclocking due to voltages etc
