This will be my 3rd such build, all guided by this forum. I built the first one in 2010 and the 2nd one in 2012. So I'm a bit overdue.
1) What will you be doing with this PC? Big spreadsheets, and lots of content creation including audio editing (with Ardour), some image editing, some software development, and a wide variety of stuff. In 2012 most commenters suggested that my build was overkill. It was not. If anything, I wish I had gone for even more performance. This time, I plan to go for the maximum performance I can get within the constraint of silence. Silence is my #1 requirement.
2) What's your budget? Roughly US$3000 not including monitors. Budget is flexible. My company is paying for it.
3) Which country do you live in? US.
4) What exact parts do you need for that budget? Please see list of parts for my last build below. I want to buy all new parts of similar, but upgraded, specs. It's a workstation. And silent.
5) If reusing any parts, what parts will you be reusing? Only the UPS, monitors, mouse and keyboard... maybe not even those. Let's say "none."
6) Will you be overclocking? No.
7) What is the max resolution of your monitor? What size is it? I will be driving three monitors. Dell 30" U3011 at 2560 x 1600 resolution.
8) When do you plan on building/buying the PC? Start now and complete it in a few weeks or so.
9) What features do you need in a motherboard?
RAID? NO
Firewire? NO
Crossfire or SLI support? Not sure.
USB 3.0? YES
SATA 6Gb/s? eSATA? YES
Onboard video (as a backup or main GPU)?
UEFI? I guess I have no choice, right? I'll be running Linux (Ubuntu 64bit version 14.04 and soon 16.04.)
10) Do you already have a legit and reusable/transferable OS key/license? N/A
Most important features are:
1. must be dead silent!
2. must be powerful/fast. The current graphics performance is lagging a bit. However, I have to stick with silent (probably passively cooled) video cards.
3. I want more internal storage than my last build. That one had a 2TB drive and a 512 GB SSD.
Here is the parts list for my last (2012) build. I will plan to buy all these items again. I'm looking for similar spec components -- workstation quality, especially the RAM.
My sound "card" will be a USB audio interface: probably the Komplete Audio 6. It's tough to find a good USB audio interface with Linux support. I know this one works well. I'll research other options separately, but for now we can assume this device will be my audio interface.
EDIT:
I just read this comment in another thread:
If that is the general opinion, and if any of that actually applies to me, then I could wait and plan to build at Thanksgiving time (November). However, given that I'll probably be buying a workstation mobo, Xeon CPU and ECC RAM, maybe the above doesn't apply to me. Thoughts?
RAID? NO
Firewire? NO
USB 3.0? YES
- Asus P8B WS LGA1155/ Intel C206/ Quad CrossFireX/ SATA3&USB3.0/ A&2GbE/ ATX Motherboard
- Xeon Qc E3-1230 Processor (Sandy Bridge CPU) LGA1155 (8M Cache, 3.20 GHz)
- 4 x Kingston 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) ECC Unbuffered Server Memory Model KVR1333D3E9SK2/8G
- PowerColor Go! Green ATI Radeon HD6750 1 GB DDR5 2DVI/HDMI/DisplayPort PCI-Express Video Card AX6750 1GBD5-NS3DHG
- Samsung Spinpoint F4EG 2 TB SATA2 5400rpm 32 MB Hard Drive HD204UI/Z4
- Samsung Spinpoint F4EG 2 TB SATA2 5400rpm 32 MB Hard Drive HD204UI/Z4 (external storage)
- Crucial 512 GB m4 2.5-Inch Solid State Drive SATA 6Gb/s CT512M4SSD2
- Crucial 64 GB m4 2.5-Inch Solid State Drive SATA 6Gb/s CT064M4SSD2
- 1 x Seagate STAW3000100 3TB BlackArmor NAS 110 Network Storage
- 1 x LITE-ON Black 12X Blu-ray Burner with Blu Ray 3D Feature SATA IHBS112-04 - OEM
- 1 x Prolimatech Megahalems Rev.B CPU Cooler
- Seasonic 560W 80 Plus Gold ATX 12V/EPS 12V Power Supply - X-560 SS-560KM
- 2 of POWER SAVING BACK-UPS XS 1500
- Ultra 120mm Fan Vibration Dampener 3 Pack
- Nexus Anti-Vibration PC Mounting Kit - 60 components
- Macally USB Slim Keyboard (ICEKEYB)
- Contour Design RollerMouse Free2, Black (since upgraded to a Re:d)
- 3 of Dell UltraSharp U3011 30-inch Widescreen Monitor
- Antec SOLO II Computer Case (Piano black)
- 3 of Scythe Kama Flow 2 120mm x 25mm Fan - 900 RPM w/ Extra Fluid Dynamic Bearing (SP1225FDB12L)
- 3 of Scythe Slip Stream SY1225SL12SL 120mm 500 RPM Fan
- Rosewill RCR-AK-IM5002 USB2.0 75 in 1 internal Card Reader
EDIT:
Come back in a few months and ask for advice then because:
1) We'll have more information on which Z170 or H170 mobo are actually good
2) The pricing and availability of the regular Core i7 CPUs should be stabilized by then.
3) DDR4 RAM will be cheaper
4) Less of a price gouging on the Z170 or H170 motherboards.
