silent cooling for a i5 system?
chronic9
I am building a mATX i5 650 rig. 4 gigs of ram, 1 SSD. onboard VGA.
I am wondering if I can create a 100% fanless PC?
its only going to be used for firefox and outlook and other random daily use activities.
http://www.svc.com/den-b.html
this comes to mind... but I am having issues if it can keep the CPU cool enough?
also considering the fanless antec PSUs there are out there.
For that application you may even underclock.
this. underclocking will get great results with keeping your system pretty much fanless. I'd still throw in a low rpm fan on the case so that airflow isn't completely stagnant (a decent 120mm @ ~900 rpm should be nearly in-audible).
sorry I can't help much with heatsinks, I know a bit more about top performing actively cooled hsf, lol. you probably don't have the room for it, but I know the noctua nh-d14 is great for passive cooling and thermalright has the hr-02, they are very large though, lol.
ya the case is made for mATX only.... and sadly only has 80mm holes
i may just run it with the fans and see how audible it is.... i can always buy a fanless PSU later
My i5 750 can run wih a 120mm Noctua fan at 500rpm on a Megahalems, haven't tried completely passive. That cooler they're advertising doesn't look like it'd have the surface area to cool completely passively.
ack, I see. silent 80mm that push decent air are a bit tougher to come by. a lot of the more decent ones make very little noise, the 80mm scythe low-rpm s-flex fans are pretty quiet. pretty much any decent brand using liquid bearings should make very little motor noise (most noise will come from the blades cutting into the air).
I would look into either the prolimatech samuel 17 or scythe shuriken, both are low profile and much better performance that what you linked
