Silent Case Fans
blade52x
What are some recommendations for case fans that are completely silent? I prefer something around 1200rpm. I've bought 1600rpm fans in the past, only to see them running at 1800rpm in the BIOS. My P67 does have a built in fan controller, however it seems like if I tone down these faster fans, they at some point start to rattle which becomes very, very annoying. So I'm looking for fans that are really designed for quiet operation. I don't want to hear a thing while the computers are sitting idle or not in game mode.
I need standard open case fans, and fans capable of pushing air through a radiator without making noise. So far I was looking at the two Scythe models below (not sure if they are PWM, if not then probably a no go), but if anyone else has any suggestions, please do let me know!
Rad Fans : http://www.frozencpu.com/products/1...Extra_Fluid_Dynamic_Bearing_SP1225FDB12M.html
Case : http://www.frozencpu.com/products/1...mm_Fan_-_1450_RPM_D1225C12B4AP-14.html?tl=g36
For rad fans, you can't really get any better than the Scythe Gentle Typhoon series. For general case fans, I've heard good things about Scythe S-Flex fans. I really like my Coolink SWiF 1201s, but they tend to make some ticking noise if oriented to blow air upward. Otherwise they're fantastic.
The low RPM Noctura series. I have mine silent (and by silent, I mean absolutely silent) at 600rpm but they are also very quiet at 900rpm and move the same amount of air as most 1200rpm fans.
Chris
I have had good luck with Scythe. Own a bunch of different ones. I can hear them if I crawl under my desk and stick my head next to the case but a few inches away they make no sound.
