A fan controller will give you a wider range of fan speeds, but you can do some wire splicing (with caution) to volt mod the fan: for 5v you just wire the fan to the 5v wire and gnd, for 7v you wire the fan between the 12v and 5v wire and for 12 volt you leave it as is
