My old file server died so I've built a new one to replace it. If possible I'd like to run Ubuntu 8.10 on the new box, but I don't know if I'll be able to. I currently have an array with 3 NTFS volumes created using the Silicon Image SATA Raid Manager tool in a Windows environment (XP SP2). Will I be able to use these volumes in Ubuntu?
I've read some very confusing and conflicting information when it comes to the Sil3124 drivers and SATA RAID Manager software in Linux. The User Guide has a section on using the RAID Manager on a Linux environment, but drivers only seem to be available for a few distributions (not including Ubuntu). I've also found something called libATA which looks like it has support for the Sil3124 in all distros of linux. Put simply I'm very confused with this whole situation. I've done quite a bit of research but I have yet to find definitive answers to the questions above. Once the drivers are successfully installed the User Guide says you need to run a deamon then run the actual Raid Manager software, but I can't find the package with the version for linux.
Can anyone please answer the questions and/or point me in the direction of some sort of guide/tutorial to getting things working? I'd really appreciate it.
