mike_in_sd
- May 3, 2008
Using Gigabyte GA-K8N mb.
Trying to install two Sata drives.
I dont need/want any fancy raid config, I just want to use both
drives normally. (singles)
using sil 3114 drivers
I have xp on the first one, and the second one for storage use.
The only raid setup that seems appropriate is the sil jbod.
When I set them both to this setting I get a MBR error 1 and it
won't boot
If I remove the jbod from the 2nd one the 1st one will boot ok.
but, then you dont see the 2nd one.
having problems here ... help !!!
thanks
mike
won't boot
thanks
mike
