Significantly Better Performance In Fullscreen Than Windowed
XacTactX
This is an interesting phenomenon I just noticed. I just got a 9600GT, and wanted to run some mock benchmarks so that I can compare how much faster the 9600GT is, and I noticed something. Check it out. The first run each time was discarded, the next three results were recorded for each run.
Intel Core i5 750 (Stock)
2 x 2GB DDR3 1333 @ 10-9-9-24 CR2
eVGA 7900GS KO 256MB @ 518/689, ForceWare 266.58
Vista Ultimate x86, Aero On
Counter Strike: Source Benchmark
Maximum Quality Settings
1680 x 1050
0x AA / 16x AF
Readings
Windowed: 50.5 50.3 50.4
Fullscreen: 71.5 71.4 71.1
Average
Windowed: 50.4
Fullscreen: 71.4 (+41.2%)
This isn't atypical. Usually the difference isn't that dramatic, but in some cases it can be.
it's almost always been that way. even in newer games you have Fullscreen(windowed) mode that fill is up like a full screen but lets you switch between apps as if you were running windowed, but you take a performance hit to switch fast like that.
Yeah, definitely remember this pretty much always being the case. Though I'm not sure exactly why; as long as there are no GPU-accelerated stuff going on( Aero maybe? Personally never used it though), I can't really see why there would be any real performance difference.
Yes, I am running Vista Ultimate x86 with the Aero interface On. I'll add that to the OP for the sake of transparency. Thanks for the comment :).
EDIT: Thanks to you all for your ideas :).
I notice in windowed mode Crossfire X breaks and the 2nd card throttles to 2D clocks which kills performance even worse than 1 card.
I'm gonna guess all kinds of things could be going wrong with the drivers trying to run a game in windowed mode.
