Hi. This looks like a good thread to put my question to. I am sure one of you techies will have an answer.
I had a PC built with Intel Core 2 Quad-Core Q6600 (2.4 GHz, 1066MHz, 8MB Cache) processor with 4GB RAM. The card is a Matrox QID LP PCIe which supports up to four monitors with resolutions up to 1600 x 1200 each. I am using Vista Business (32 Bit). I want to connect four 37" LCD screens to the system. These screens are LCD TV's made by LG model no. 37LC55 supporting resolutions up to 1366 x 768. I only want to use 1024 x 768. I am attaching these diplays using DVI (on the PC) to HDMI (on the TV) cables, 5 meters long each. The displays also have a VGA connection.The Matrox card comes with four DVI-D outputs but also has the VGA adaptors.
The problem I am having is that the signal is dropping most of the times as early as the startup of Windows. If I attach more than one monitor the system does not even start. Any ideas where the problem is? Is it the type of connection, length of the cables or is there a problem with the card? Matrox say that the have not tested the DVI to HDMI cables. I am quite surprised as this is probably quite a popular combinition as most PC's have the DVI and almost all LCD TV's come with HDMI. They also say that DVI-DVI should be no more than eight feet if used and the VGA may give better results but still has the same cable length restriction.
The problem is that I need the 5m length as I'll be placing the PC away from the monitors in a commercial premises.
Any ideas??
Any ideas??
