Ok, for about 2 weeks now ive been getting a few random reboots where the system would suddenly hang and then before I know it I am looking at the video card bios screen upon reboot.
I really could use some help as to what it could possibly be, so far ive tried relaxing memory timings as far as possible and its still continues to happen.
I've also tried better cooling, installed a new watercooling system in this machine its not getting that great of temps but it is cooler than it was on air... :\ (38*C at idle 46*C at full).
Now im fairly sure its not my psu (Antec TruePower 480w and never had problems with it before) but if you guys think it could be that I could try changing that out as well.
Another odd problem which im not sure if its related is that when I boot up and if I have to scan disc it will either hang for sometimes a few minutes after hitting any key or after going through the whole scan disk check. Usually it stops and just sits on the scan disk screen for anywhere from 30 seconds to sometimes quite a few minutes) but will always eventually go into desktop. I've done a reformat about 2 and a half weeks ago so I really dont know what could be causing the disk hanging.
Im really starting to wonder if I have a bad chip or motherboard and thats causing all the problems im getting, random reboots, system hangs (in scan disc) and fairly high temps even with watercooling.
Btw, I have checked and rechecked my watercooling setup, ive reseated the waterblock about 5 times so far all with these high temps, and yes I am using silver thermal paste.
Sorry for the long winded posted, hopefully someone out there can help me out. I could really use it. Thanks.
