LostInRehab2
- Jun 25, 2006
Ok, I got my 8800gtx back in november 2 days before thanksgiving and all was well. Played Oblivion,dark messiah, GRAW, HL2 all at maxed settings no problem. Then my motherboard died so I had to put it up for a while till I got my rma replacement. Now that I got a replacement motherboard everything seemed fine or so it seemed since I was playing San andreas for a few days straight (game isn't very gpu demanding) but after a while I finaly took a break from gta and reinstalled oblivion and fired it up the frame rates were horrible. I thought that it was probably the performance decay a few other people were getting after a few restarts. So I reformat and get a fresh install of windows fresh 97.44 driver install install oblivion and the frame rates are still low. I did it a second time full format and windows install except using the drivers that came with the card same oblivion performance. My computer specs are; E6300 stock (was @ 2.8 but reset it back to stock just to be sure), Asus p5b dlx wifi, crucial 10th anniversary ram, corsair 620HX psu.
Edit: forgot to mention this is at1280x1024 resolution so you can see why this is a problem. Yeah the 8800gtx is overkill but I'm trying to find a good 22" monitor that I like.
