Stevennoland
- Jan 5, 2006
Since I'm in limbo waiting for my custom case to be manufactured by Mountain Mods, I figured I'd update my previous water cooled build (Beast 2.8). There is a build thread under the same name if you'd care to see what went into Beast 2.8. Short and sweet, that system consisted of an Intel i7 - 920 with an Asus Rampage II Extreme mobo with 12 gigs of RAM. That system also had my first SSD; a 160 gig drive from Intel. I remember that sucker cost a shit ton! It also had a GTX295 vid card with a Heatkiller water block. That thing was super heavy. I had all that housed in a Lian Li Best Buy branded Rocketfish case. It was ok for its time, but that was more than 2 years ago, and in computer time sense, ancient.
I happened to be perusing the cases at Fry's Electronics and came upon a new case from Corsair. It caught my eye because of its shape. Cube to be exact. It is the Air540. You can read all about it online, but here are a few shots of the case.
Bottom
Window
I was going to use the GTX 690 in my 'The Beast' build, but then the Titan came along so this got put on the shelf. Why not use it for miniBeast. I came up with 'miniBeast' cause it's a smaller version of 'The Beast'. Pics of the vid card.
Nothing special by today's standards. I was a little pissed when I went to put the back plate on. I stripped the heads off four screws! After the first two, I did the suggested routine; put the card in and let her warm up. Did that. And two more popped off. We'll see how it goes.
I knew I wanted to update the mobo and proc, so while I was at Fry's, I picked these up.
CPU
After I got home from Fry's, I started doing some research on 1150 mobo's from Asus. I found the Maximus VI formula with the built in waterblock. Sweet board, but I don't know about that aluminum waterblock. Anyways, I'm sure the Deluxe will be fine. Some pics of the mobo.
I'm not real fond of the gold, but it should go well with the red parts I'm putting in miniBeast.
I knew I was going to watercool, so when I tore into the Air540, I wondered if she could house some Aquacomputer Airplex rads? I had ordered some 240mm rads by mistake for 'The Beast', so why not use them here? With a little luck, they should work. Test fit.
I want to get some red anodized sides for the Airplex rads. I think that would look sweet. Just waiting on UPS. Ordered a bunch of stuff from FrozenCPU.
Here are a couple pics of the SSD. Not sure if I'll do a RAID 0 or just stick with a single drive. Hmmm.
I ordered this bay res for 'The Beast' but I think it would suit miniBeast better. Not sure how it will do being rotated 90 degrees. Should work.
That's all I have done now. Just waiting on UPS, along with everyone else. Come on UPS. Hurry the eff up! Damn holiday weekend put me behind!
Stay tuned!
Bottom
Window
CPU
Stay tuned!
