side panel?
oSHEVANELo
Hey I have an Enermax cs-125 mid tower case. I want to get a side panel for it with a fan down by where the agp slot for the video card goes to get the vid card properly cooled. Where can I get a side panel like that? Ive seen em before in this forum but i couldnt find it. Or is there anyway i could cut through the acrylic window and install a fan?
How to cut a fan hole:
Take side off of case
Mask off area to get the hole
Measure out everything 2 or 3 times (youll be happier later)
While measuring, mark on the masking tape the center of the fan hole and mounting holes
Measure 2 or 3 more times
repeat if neccisary
cut fan hole with sutably sized hole-saw
drill mounting holes
Done!
