Side panel question on Mystique 631
andrus
I'm going to buy this case and a fan for the side panel but I can't find out what size fan it can hold on the side. Looks to me like 92mm? Can anyone confirm that? And if I were to put a fan there, it should be an intake right? Would that bring in a lot of dust inside (I despise cleaning my case)?
http://svc.com/rc-631-kkn1.html
I have the clear panel side version and it is a 120mm on this one.
Hmm.. Do you think they could be different sizes? The window one does look a bit bigger to me. Does anyone have one without a window? If not I'll just hold off on the fan for now..
Yes, they are in fact different sizes, the non-window is 80mm. Compare it to a TT Tsunami (92mm) for instance, the hole is smaller.
