You should be more worried about buzzword design cases done just for the sake of weird design and empty marketing buzzwords.I would love to see someone with one of the cases that allows the drives to be rotated to do a temp test to see how absolutely terrible this side mounting is for air flow and temps.
Going from the PC-B70 to the Raven, I GAINED(!!!) about 7 to 10* Celcius on my CPU temps
http://hardforum.com/showpost.php?p=1034567466&postcount=1
Any design needs some thought to work:
RV02 is awesome and a great improvement over the Raven in many areas - one of which is the overall cooling... CPU temps in the RV02 are on par with the LL PC-B70, which to date has been the best air-cooling case I've used.
http://hardforum.com/showpost.php?p=1034568604&postcount=9
The way I see it, long mounted HDDs have the cables usually stuffed between them, at least that is what the cables do in my 900 case. The excess is stuffed between the drives. Not talking about the excess non used cables, I mean the extra length on the OEM cable for my Corsair 620HX. I am sure that does not impede airflow at all though.![]()
Too bad that half of the time innovations come from marketing wanting bulletpoint-engineering.But anyway, I hope case manufacturers keep pumping out regular tower cases with regular interiors instead of trying to innovate. That would be awesome.
