- Apr 26, 2009
I'm getting closer to completing my PC build, but I would like to buy a window panel for my CM Storm Sniper. I really want to know if I would benefit more for keeping my side fan or just buy the window panel. Since the build is not complete, I'm unable to test the airflow and I don't know when CM are going to end the sale on their windowed panels.
This has a lot to do with positive and negative air pressure. I'm also using the Corsair H50, so this makes airflow even more complicated. If I add or remove certain fans, I may achieve the same cooling results without a side fan. I know that the HAF 932 benefits greatly from a side fan, but in other cases the side fan interferes with the natural front to back airflow.
I'm thinking:
(Front, Side) Intake (Top, Rear) Exhaust
or
(Front, Bottom) Intake (Top, Rear) Exhaust (Window)
Suggestions, advice, comparisons?
http://icrontic.com/articles/pc_airflow_heat_cooling_guide
I'm thinking:
or
