side by side 240mm rads...
nightwalker
are there any rads that will fit snug next to each other ? i plan to mount them in a mozart tx where it has 4x120mm fan holes in a square. i know my BIP 240's would be no good because they are bigger dimensions than a 120mm fan.
any suggestions ?
All the 120mm rads are bigger than the fans that mount to them.
Maybe you could put one rad inside and one rad outside?
