I have a window 120mm side air intake. The outside of the intake has a FilterRight clear aluminium fan filter. What I was thinking of doing was replacing the FilterRight with a stainless steel Fan Grille and then using an A.C. Ryan Meshx Fan guard under the grille.
Which set-up is better for keeping out dust and particles? I'm not sure if the A.C. Ryan allows good air flow, but still keeps out the particles. Does anyone have any experience with these 2 filters, and which set-up would you recommend.
I like the grille idea, but that part is purely for aethetics.
