sick system shuts down on boot
Far
specs:
ASUS P5GL-MX Socket T (LGA 775) Intel 915GL Micro ATX Intel Motherboard - Retail
Item #: N82E16813131543
(Serial #: 56MM1L9076)
For Asus Tech Support, Please Call 502-995-0883 or http://helpdesk.asus.com/ $74.00
Track 1 WinFast PX7800GTX Geforce 7800GTX 256MB GDDR3 PCI Express x16 Video Card - Retail
Item #: N82E16814122224
(Serial #: L5070042089)
This item is service by the Manufacture Directly. Leadtek Tech Support : 1-888-532-3835 $499.00
Track 1 intel Pentium 4 550 Prescott 800MHz FSB LGA 775 Processor Model BX80547PG3400E - Retail
Item #: N82E16819116182
(Serial #: 7.023614)
Intel (800)-628-8686 Please Verify Processor matches order Prior to installation. IMPORTANT: Always pack you CPU well for return. We will refuse your RMA if we received it as DAMAGED! $269.99
Track 2 pqi TURBO 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model PQI3200-2048DP - Retail
Item #: N82E16820141182
(Serial #: ZCMBMMJAFUHA5, ZCMBMMJAFUHA70) $374.88
Track 1 Western Digital Caviar SE WD3200JD 320GB 7200 RPM Serial ATA150 Hard Drive - OEM
Item #: N82E16822144394
(Serial #: WMAMR1428775)
This item is serviced by the Western Digital. Please call 800 832 4778 for service. $168.00
Track 1 SUNBEAM EL-KB-05-AC transparency PS/2 Wired Standard Illuminated Keyboard - Retail
Item #: N82E16823178101
(Serial #: 0DSSC507000001P) $17.00
Track 1 Sunbeam FireLine Optical Mouse MS-2011-BK-BL Black 3 Buttons 1x Wheel USB Optical Mouse w/Blue Light - Retail
Item #: N82E16826178003
(Serial #: 6927922001998) $8.99
Track 2 Gigabyte Black IDE Combo Drive Model GO-B5232A-B - Retail
Item #: N82E16827200003
(Serial #: SN0515007866, SN0515008100)
Gigabyte (626)-854-9338 option 4 www.giga-byte.com $57.98
Item(s) shipped from TN Tracking Number: #708474320356
Track 1 ASPIRE X-QPACK-AL/420 Black/Silver Aluminum MicroATX Desktop Computer Case 420W Power Supply - Retail
Item #: N82E16811144109
(Serial #: 06MUUL0600000C9)
Heres the problem... We start up and the computer shuts off completly after no longer then 10 seconds....you can hit the power and turn it right bakc on but then it stays on for even less time then the time before.....
ANY ideas????
sounds like your power supply hates life T-T. Id recommend 520 with a 7800...but that's just me..
edit: wow my grammar was horrid there...
I was thinking PS too. A setup up like that need alot of power.
It cant be the PSU, because I tried running it barebones...just mobo, cpu, and the psu, and it still shuts down. Replaced the 4gb of ram to 256 just for troubleshooting too, and it still hangs. As for the PSU, I tried it in my other machine, and it works just fine.
um, make sure you have the right amount of thermal paste and that the cooler is mounted properly... you can also make sure your P/S is dust free... copious amounts of canned air can be your best friend...
Take out all cards but video... disconnect hard drives and opticals from power/data and see if it boots...
Far, please don't use words like "ass" in thread titles. You might want to review the rules you agreed to when you registered here.
Okay, had some guys over, we tried several things with no luck for several hours. Changing jumpers, trying other power supplies, the whole nine yards. No luck. We determined the problem is a faulty motherboard, and it is being returned for a full refund. I'm gonna go pricing the shops around here to get a new motherboard immediately, because I don't feel like waiting for a new one to ship.
Thank you for all your help though. Pece
