SI-128 optimal fan
Xilikon
[H]ard|DCer of the Year 2008
I ordered the Thermalright SI-128 yesterday to take advantage of the 15$ PayPal gift and the order didn't include a fan because I'm not sure which one to get...
From what I read in the reviews of the heatsink, it has a lot of fins, which need a more powerful fan to be able to cool it off very well. Low noise fans are not really powerful or optimized for this beefy heatsink. I need to find out which 120 mm fan to buy which have a very good balance of high CFM and reasonable noise level (something around 30-35 db, a bit more if needed) who can cool off the heatsink the most, and also the mosfets / northbridge of the D975XBX2. I would hope to get a 25 mm high version instead of the 38 mm due to the case side clearance.
What are your suggestions ? budget is not a concern as long as it's not 50$ a single fan ;)
No its not Photoshopped. lol
There's certainly something funny going on either in software or sensors, there's no way in hell your HDs could be that cold after running for a while. Unless you're outside in a northeast winter. Your GPU temps look too low as well.
As for fans I'd look for something in the 100-130CFM range with a fan controller. Total outlay <$50 and you can use it with other things as well. Sidewinder Computers has tons of them.
The Scythe SFF21F looks interesting so i'll probably pick this one. Does anyone have better suggestions ?
ive also ordered a SI-128 and with it i ordered the silverstone FM-121 which has a max airflow of 110 cfm and it comes with a free fan controler so you can use turn it up or down like a normal HSF
That's perfect for me... 110 cfm max is very high and with the controller, I can find the sweetspot without worrying about picking the right one. I'll order one asap :)
Thats exactly what i thought when i ordered my SI-128!!:D
